23-04-2011 #32
The compound slide should only be used FOR cutting tapers, everything else you should use the saddle/apron
The only way to test is with a test bar that fits in the spindle taper and use a dti any other method you will be bringing other factors into the equation by making test cuts "Tool Deflection, Materiel Deflection ETC"
The only part that needs to run true is the cross slide to the spindle axis.
Phil
The Following User Says Thank You to M250cnc For This Useful Post:
Setting the zero point on a CNC lathe
By Robin2 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 20-10-2013, 10:37 PM -
Colchester Chipmaster Lathe HELP !!!
By snookaman in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 28-08-2013, 10:23 AM -
colchester student 1800 help with knowin what my lathe is capable of
By whensparksfly in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 26-01-2012, 03:30 PM -
By whensparksfly in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 26-01-2012, 01:26 PM -
Colchester Student 1800 Square Head Lathe - HELP !
By cncroger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 03-02-2008, 08:28 PM
