Thanks, I'll have a look where I can get them. Do you think I should remove the old oil and clean it up a bit first?
Edit:
Found it on eBay:
http://cgi.ebay.co.uk/Premier-ISO-32...item19c370ed6a
and
http://cgi.ebay.co.uk/Premier-Slidew...item19c434faaa
Hope that's enough!
This is a better deal if not:
http://cgi.ebay.co.uk/Hydraulic-Oil-...item2562b7e483Last edited by Jonathan; 19-04-2011 at 11:09 PM.
19-04-2011 #2
Just thought - the misalignment on the chuck could be the headstock that's out of line. I'll check it by putting the DTI on 'top' of the bar, then the 'side' to see if they're different readings.
In the manual it says 32 and 68 oil, I should have read it properly!
Setting the zero point on a CNC lathe
By Robin2 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 20-10-2013, 10:37 PM -
Colchester Chipmaster Lathe HELP !!!
By snookaman in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 28-08-2013, 10:23 AM -
colchester student 1800 help with knowin what my lathe is capable of
By whensparksfly in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 26-01-2012, 03:30 PM -
By whensparksfly in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 26-01-2012, 01:26 PM -
Colchester Student 1800 Square Head Lathe - HELP !
By cncroger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 03-02-2008, 08:28 PM
