Thread: W300 CNC Router
Hi David
Here is a google page for the machine
http://sites.google.com/site/w300cnc/
Yes I work full time as an engineer. One of the stepper drivers burnt out as I bumped the axis speed up in Mach which caused the issue.
Between myself and the electronic engineer at work we designed and built a totally new 4 axis PCB. The build can actually be viewed here
http://randomprojects.info/
The PCB should be up on his website this week.
I modified the housing and added a 60mm fan, relay to switch off the spindle motor.
The motor must be switched on manually before starting the program and will switch off automatically now. Also we got new stepper drivers which have overload (temperature protection) and if they get too hot they will stop rather than burn out as on the older standard ones. We also changed the capacitors as the builder previously used ones which were actually at the limit as regards voltage. Now there is an acceptable factor of safety. We added windings to the transformer also to improve it.
I haven't setup the 4th axis yet but have had it in motion. I will have my new Denford Monday so wont have any need for the router but I find it very sturdy and it has nice travel (309 x 309 x 85).
Brian
18-05-2011 #2
Machine now sold
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
