    Hey Guys,
    I'm new to this forum but have been using the Denford Triac 3 axis CNC machine (in standard form) in my shed for a couple of years. I've been very impressed with its ability to work with tougher materials which I regularly work with when building fighting robots.
    Recently, the spindle has stopped working. The relays still audibly 'click' but the motor doesn't even try to rotate. This is the case for both forward and reverse. The rest of the machine (3 axis movement etc) seems to function perfectly.
    I would welcome any advice on fault finding or any experienced suggestions to indicate which part has failed.
    Many Thanks,
    Sam
  2. Spindle motor windings may need to be re - wound
    i2i's Avatar
    are you using denfords controller, or mach3
    Hi Guys,
    The strange thing was that while I have pushed the machine hard in the passed and got the spindle motor quite warm, on the occasion it failed it had just finished some light pocketing in ali finished the program and spun down. This made me think it was a motor driver or possibly a relay failure. I'm using the standard Triac software (all manually G coded).
    As i'm not sure which model or year the machine is, i've uploaded some photos for identification.
    Thanks,
    Sam
ID:	3997   Click image for larger version.
ID:	3996   Click image for larger version.
    i2i's Avatar
    unfortunately there's not a lot of info available for this early version. Check the fuses on the back panel as there may be a seperate fuse for the spindle. Check the fuse on the spindle inverter (rear left), it may be that the inverter has failed.
    Thanks for the tips, I've checked the 3 fuses I can see on the main board, and two more in plastic screw cases towards the back of the machine on the left. They all look ok, are there any others I might have missed?
  1. Denford Triac Mill
    By DaveMann in forum Denford Mills
    Last Post: 12-01-2017, 10:43 AM
  2. FOR SALE: Denford Triac PC for sale
    By i2i in forum Items For Sale
    Last Post: 12-01-2017, 10:01 AM
  3. Denford Triac VMC
    By fidia in forum Milling Machines, Builds & Conversions
    Last Post: 19-08-2016, 08:18 AM
  4. FOR SALE: Denford Triac
    By asto in forum Items For Sale
    Last Post: 07-02-2016, 08:28 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 08:17 AM
