Thread: spindle bearings overheating
I was running today machine non stop for 4 hours and after I couldn't keep fingers on spindle as well. I never paid too much attention to bearings temp until I read your post :) That's the DIY spindle filled nearly entirety with synthetic engine oil with a little air gap. When I mill next time I'll do the temp checks in some time periods.
I'm awaiting for your update
05-05-2011 #2
Are your bearings too tight? It's very easy to over tighten them when cold (BTDT), especially if the expansion tends to tighten them.
Try backing them off a bit.
Bill
13-05-2011 #3
Hi Andrew, Not sure if you have solved this problem yet?
I hope I've understood you problem I I think it might be the seals ( as you suspect) and the oil!
firstly wheel bearing seals are designed to keep al sorts of nasties out but at relativly low speeds, once you put them in a spindle the extra friction is a problem, low or zero friction seals are a must in a spindle.
Secondly over greasing or over oiling is the worst thing you can do to a spindle with regards to heat, as the shearing action within the oil that allows the parts to move easily generates heat.
as Bill mentioned it is easy to over tighten the bearings, but it depends on the orientation of the bearings. if they are face to face then if I remember correctly you need to preload them so that as the shaft grows under heat the correct loaing is acheived as the extra length reduces the loading, BUT if they are back to back then any heat generated will add extra load on the bearings and in turn generate more heat.......visious circle ect.
This could be be your problem in that the original seals are generating a bit of heat(plus to much oil/grease) which in turn is putting load on the bearings, which is then generating heat and so on and so on.....
Im no expert but I have been looking in to this for my own spindle and it seems that spindles are suseptible to any small change,be it heat, vibration to over loading the tool.
sorry for the ramble, just ignore it i have got your problem it all wrong. Let me know how you get on tho
15-05-2011 #4
Thanks all for the advice. I am still waiting for the new bearings so I have not made much progress on the problem yet. I have made a guard for the spidle belts and am making way covers. But when I get around to it I will post on my build thread.
Overheating stepper motors
By Skysurfer in forum Stepper & Servo MotorsReplies: 3Last Post: 01-08-2019, 11:43 AM -
By Skysurfer in forum Motor Drivers & ControllersReplies: 2Last Post: 06-05-2014, 12:40 PM -
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM -
FOR SALE: rails, screws, bearings and spindle
By wilfy in forum Items For SaleReplies: 16Last Post: 10-04-2013, 01:50 AM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
