    I guess a diy cnc is never quite finished but this one is about as finished as its going to get
    im pretty happy with how well it all worked out :)
    good luck to all you buggars half way through your build.... try not to sup to much WD40 :)
    Nice one. Im glad you got it all finished. Nice bit of video too.
    Regards
    Ian
    ecat's Avatar
    Location unknown. Last Activity: 08-02-2014 Has been a member for 9-10 years. Has a total post count of 157. Received thanks 5 times, giving thanks to others 8 times.
    Grats! Excellent video :)
    Agreed, nicely edited video. Have you got any high resolution pictures from it? It looks like you've made another spindle and put a fly cutter made from a lathe tool in it?
    of the machine or the spindle ?
    your half right jonathan
    its the same 2000w spindle with a simple flycutter i modified, (my main work horse.. the other two spindles i made dont get used very often)
    the un-holy jumbles of it all is hidden in the video (art ) but here it is naked and looking scruffy, it works nice though
    this is the last thing i made for the machine
    3.175mm carbide shaft through brass, i cut up a torsion spring from a large shaft oil seal as the stops, simple and easy to adjust
    i think the secret to getting these drag engavers to work well is grinding a good accurate point, i could probaby do with trying a more shallow angle with this one but its working well enough for me to just let it be untill it needs sharpening :)
