I've been using Framework which is freeware but has some limitations. Runs fine on a 2GHz laptop and gives a good idea about deformation under load of a gantry for instance...
I'm interested in your suggestion of HDPE... there was a recent discussion here about PVC v Ali for construction and a bit of research suggested that PVC was about as rigid as MDF but stronger in tension. When I looked at other plastics, including HDPE, I wasn't impressed by much of them as compared to thin-wall Aluminium box section which, weight for weight is more rigid and stronger. Can you shed any more light on this? PVC was much more expensive as well....
NEW MEMBER: Hello from Suffolk
By lockyg in forum New Member IntroductionsReplies: 10Last Post: 20-07-2011, 01:08 PM -
NEW MEMBER: New member from Essex
By swarfy in forum New Member IntroductionsReplies: 1Last Post: 08-12-2010, 01:38 PM -
NEW MEMBER: New member fron Cambridge
By GeoffV in forum New Member IntroductionsReplies: 3Last Post: 30-09-2010, 07:25 PM -
NEW MEMBER: Hello from Lowestoft, Suffolk
By ciscokiduk in forum New Member IntroductionsReplies: 0Last Post: 19-04-2009, 09:37 PM -
NEW MEMBER: New Member - Essex UK
By alan2525 in forum New Member IntroductionsReplies: 1Last Post: 16-10-2007, 01:43 PM
