19-05-2011 #1
Evening gents,
i have just bopught a Leadwell MCV 610 vmc 1988 model using a fanuc OM control, and i have not got a clue how to make it move,
things i need to help ther job along.
i need the software that allows uploading of programs for laptop
manuals hard copy of download
someone to come along and show me,lol
i have wired it up and turned it on , at first the screen showed xyz posititons, but now it shows error codes 416, 426 and 436, any ideas men
as usual help greatfully received, and if this is in the wrong section please move accordingly
regards carl
20-05-2011 #2
Its been a very long time since I worked on a Fanuc controller. It sounds like you have encoder problems. I would doubt that all encoders have failed at the same time unless your power supply has blown them up. Have a look at the power supply and check the voltage is within the required parameters for your machine. With most controllers the +5volts needs to be a good solid supply normally around 5.1 volts and shoudnt drop. Also could be a fault with the encoder feedback pcb or maybe the machine settings have been corrupted. Unfortunately I cant tell you how to check them.
Regards
Ian
26-08-2011 #3
Just sharing to you, if you wanna learn about cnc fanuc troubleshoot, hopefully could be useful
cncfanuc.blogspot.com
NEW MEMBER: Fanuc Macro programming
By curly3456 in forum New Member IntroductionsReplies: 0Last Post: 02-02-2012, 10:20 PM -
FANUC 10TF Profiling problem
By macca5 in forum Programmers CornerReplies: 1Last Post: 06-12-2011, 12:47 PM -
NEW MEMBER: hey guys, help fom experienced fanuc controlled cnc programmers needed. thanks
By benread89 in forum New Member IntroductionsReplies: 1Last Post: 18-08-2011, 04:20 PM -
Leadwell/ Fanuc Om control manual
By fastcarl in forum Machine DiscussionReplies: 0Last Post: 26-06-2011, 11:09 AM
