	01-06-2011 #1
once i get my cnc machine so i can cut panels out of 18mm 4 x 8 laminated mdf, i need to slot the edges of the panels with a 2mm kerf in the center of the edge which is 9mm down. i have seen slotter/groover router bits for doing this and was planning to slot them by hand once the panels were cut.
is it possible to slot them on a cnc router though? i know the slotter bit is much wider compared to a normal cutting bit.
is the solution to arrange my panels on the 4 x8 sheet cad drawing so that most of the out edge is the edge that needs slotting and i can get most of the slotting down automatically.
or maybe set up another program where i can line up all the cut panels after they are cut on the machine and just run the slotter down the edge in a single pass, flip the panels run it again.
does anyone know if this is a realistic possibility?
i've never used a cnc before
	02-06-2011 #2
Quite feasable using a slotter you will have to make a jig to hold them off the table as router slotters have a nut on the end that holds the slotter blade and whatever you are cutting will have to be raised so the cutter clears the table.
You will have to slot after you have cut your panels out of the 8 x 4 sheet.
Trend have a biscuit slotter that you could use http://www.trend-uk.com/en/UK/trend/...ledge&id=15073
PeterLast edited by ptjw7uk; 02-06-2011 at 12:12 PM. Reason: url
edge finish - ripples and ridges
By dsc in forum Metalwork DiscussionReplies: 9Last Post: 08-07-2013, 08:53 PM -
1/4" / 6mm edge finder?
By jcb121 in forum Marketplace DiscussionReplies: 0Last Post: 18-03-2013, 02:58 PM -
cutting a chamfered edge
By wyndham in forum General DiscussionReplies: 9Last Post: 02-07-2011, 01:02 PM -
is it possible to slot the edge on a cnc?
By wyndham in forum General DiscussionReplies: 2Last Post: 21-06-2011, 12:25 AM -
Edge Finding For Newbies
By M250cnc in forum CAD & CAM SoftwareReplies: 14Last Post: 01-03-2011, 10:55 AM
