Thread: Spindle2 board Mach3 set up
Simon
Do you have a seperate 12v supply for your spindle board or did you buy the one with the 12v DC to DC converter?
The PWM boxes have nothing to do with your step/direction board so no need to enter anything there.
So long as you have set up the the correct pin numbers for the step and direction on the motor output tab there should be no need to enter anything to the same pin number for it to work.
Don't forget if you cannot get it to work you could have a faulty board.
Andy
DIY 3020 CNC I/O Board
By Pointy in forum Electronic Project BuildingReplies: 10Last Post: 27-07-2015, 10:48 PM -
eBay: Denford Novamill SmartStep Control Board + Spindle Board
By danielbriggs in forum Items On eBay UKReplies: 0Last Post: 30-05-2013, 06:52 AM -
eBay: UIM2901-5A Mach3 breakout board with spindle speed control
By Fivetide in forum Items On eBay UKReplies: 0Last Post: 05-02-2013, 07:25 PM -
What board should i get ?
By Stephen-Niall in forum Motor Drivers & ControllersReplies: 4Last Post: 22-04-2012, 09:37 PM -
can mach3 burnout transistors on a CNC control board?
By kevinb in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 29-11-2010, 04:24 AM
