Thread: Hi - northern newbie
That sounds like something that could be made quite easily if you're only using it to cut MDF. As Robin says, read around on the forum and you'll find plenty of information to do it. Have a look at some of the build logs.
What cutting area do you require? If it's cutting the MDF out then a vacuum table is the easiest (and also most expensive) option. Given the number of parts you're making it's probably worth it.
NEW MEMBER: Hello from Northern Ireland
By jonnydeen in forum New Member IntroductionsReplies: 0Last Post: 13-05-2012, 02:03 AM -
NEW MEMBER: Hello from Northern Ireland!
By MikeMorgan in forum New Member IntroductionsReplies: 0Last Post: 05-05-2011, 03:29 PM -
NEW MEMBER: New from Northern Ireland
By boxmaker in forum New Member IntroductionsReplies: 1Last Post: 25-11-2010, 06:45 PM -
NEW MEMBER: Hello everyone from northern ireland
By p4tvw in forum New Member IntroductionsReplies: 4Last Post: 19-04-2010, 01:34 PM -
NEW MEMBER: Hi from Northern Ireland
By m_morgan in forum New Member IntroductionsReplies: 1Last Post: 25-09-2009, 06:48 AM
