Thread: Miling Aluminium
Hi All,
I need some advice. I have a Myford VMC (Knee mill like the chester 626) with a 2Kw 3 phase Inverter controlled motor.
i am trying to mill some 6mm thick aluminium plate. this materil came with a plastic film on one side.
i have tried using a 6mm 2 flute slot mill (Roebuck 020166) to mill a slot and all i achieve it clogging the cutter and the hole sides look like a piece of putty that someone has poked a finger trough i.e. the sides are peeled back as if it has over-heated.Regards,
Roy Stark
25-06-2011 #2
are you using coolant.
As soon as the cutter clogs you will get an extremely bad finish, was it cutting well before it clogged.?
25-06-2011 #3
no i dont have a coolant system. but i suppose i can rig up something to drip (fast) onto the job.
i start to clog almost immediatly. i have tried varing the spindle speed but ge the same result.Regards,
Roy Stark
25-06-2011 #4
sheet ally is usually pretty soft, and will gum up quickly. Try a hand spray with suitable coolant.
The Following User Says Thank You to i2i For This Useful Post:
25-06-2011 #5
Cooling is not important for ali, what is important is stopping the chips sticking to the bit as it's a soft and gummy material. Quick and easy would be WD40, get a can of that with a quick squirt as it goes to keep it lubricated, if your pocketing stop frequently to clear chips, you don't want to be re-cutting them.
Other way of doing it is if you have a compressor, keep a jet of air pointed at the bit to blow the chips away. Coated bits are also good for ali.
..........Rikk
25-06-2011 #6
Sounds like the cutting edge has picked up a layer of gunge and isn't a cutting edge anymore. Prise it off with a screwdriver. As soon as the edge gunges you stop cutting, start cold forming and the finish goes to pot.
Silly question, but if you don't know what's going wrong you could be a noob. Are you trying to do a 6mm slot in one pass with a 6mm tool? :heehee:
The Following User Says Thank You to Robin Hewitt For This Useful Post:
25-06-2011 #7
Wats a "noob". i am trying to do the slots in .5 -.8mm passes.
i used the same slot drill to clean/squar the edges and those seemed to work OK, but if i try slot citting/milling the tool fouls um within 1mm. it was till early this morning a brand new tool. this is first usage.Regards,
Roy Stark
25-06-2011 #8
[QUOTE=croy;22556] i am trying to do the slots in .5 -.8mm passes.
/QUOTE]
I did 3000rpm while slotting 2mm deep/pass (I can try to find cambam file to check feedrate but I think 60mm/min 4mm dia 4flute) with coolant of course. results: http://malamuterun.co.uk/CPU%20water...ter_cooler.htm
The Following User Says Thank You to wiatroda For This Useful Post:
25-06-2011 #9
i'll try this again in the morning. have to go out this afternoon.
Waitroda if i can get a result anywhere close to your i'd be happy. thanks all for advice.Regards,
Roy Stark
25-06-2011 #10
BUILD LOG: Aluminium CNC log.
By jcb121 in forum DIY Router Build LogsReplies: 111Last Post: 04-04-2012, 01:37 AM -
First Aluminium cut
By luke11cnc in forum Computer SoftwareReplies: 15Last Post: 24-02-2012, 09:39 AM -
RFQ: Aluminium sculpture to be CNC'ed
By dav in forum Projects, Jobs & RequestsReplies: 6Last Post: 07-01-2012, 04:37 PM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
