Hi Steve
That looks pretty useful for my router bed. It looks like just 'normal' aluminium plate, or is it tooling plate?
Just worked out that's 66Kg, probably too much to post...the best I can find is £24 plus VAT but only up to 50kg, or £60 plus vat up to 1000kg.
How much do you want for it? My Dad might be nearby soon, so might be able to collect.
Hi Jonathan..
£80.. The whole piece cost me £220 Including del.. This is exactly half of the original plate, and minus delivery, so reckon that's fair.. Will dig out the cert as cant remember which grade it is..
Steve..
03-07-2011 #3
Hi Jonathan..
Think you might have overestimated the weight.. Will weight it in the morning for you..
Steve..
03-07-2011 #4
Yep, I got that completely wrong! For some reason I used the density for steel, not aluminium. That makes it 22.5kg, which is much more reasonable. Using www.parcels2go.com the cheapest for that mass is £10.67 including vat (City Link standard). I take it you are prepared to post it?
I'll have a think and get back to you soon. Ideally I would want 2000x950mm for my machine, but I'll go for less to save money. I just need to check how well it will fit. If you can find what grade it is that would be nice, but not critical. As long as it's not impossible to machine I'm happy...
Thank you,
Jonathan
03-07-2011 #5
Just had a thought. I've got a transformer that will output 40V, so rectified that's about 55v (including the diode forward voltage). I could add the components to make a power supply for your steppers and maybe we could do a deal? The transformer is plenty big enough, would be sufficient for about 5 of your steppers I think ... will work out properly how many in a bit.
eBay: 8x4 sheet of 25mm thick aluminium plate.
By T0rnado69 in forum Items On eBay UKReplies: 0Last Post: 18-04-2014, 02:01 AM -
Clamping nut - ER11 collet... am I being thick?...
By Doddy in forum Tool & Tooling TechnologyReplies: 2Last Post: 31-01-2014, 07:05 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
RFQ: Marine Ply - 18 mm thick as attached image
By sportage in forum Projects, Jobs & RequestsReplies: 1Last Post: 04-03-2013, 10:01 PM -
Drill 4 x 28mm holes through 44mm thick aluminium
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 30-09-2012, 09:17 AM
