Thread: New and confused!
Do you want to make the plates that you can cut items from paper? For example if you wanted a star shape you want to be able to cut that out of steel? Plastic? The. Put in one of them little hand powered paper cutting machines? Also how sharp / clean do the edges need to be?
Ant
10-07-2011 #2
Had a few thoughts re your question you dont mention your useage expectations but, off the wall sugestion 1. could you perhaps look into etched dies ie photo etched plates, male and female. Could be a relatively low cost low use option plus your artwork will last indeffinitely. Off the wall sugestion 2 I have worked on LOM machines in my rapid prototyping days. These were made by a co called Helysis, The LOM stands for Laminated Object Manufacture.Basically a CNC gantry laser paper cutter. This tech is now old hat by modern standards but could be sourced cheaply and there is still backup available. Look at the 2050 model not 1015.
Bell me on 01502 712574 if i can help more.
New Build Advise Ive Got Myself So Confused ! Please Help !
By grain_r in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 26-07-2014, 01:21 PM -
Confused need help!
By manofgresley in forum CAD & CAM SoftwareReplies: 12Last Post: 08-08-2012, 08:30 PM
