Thread: chinese spindle cooling
hi all. expecting delivery of my 3hp chinese water cooled spindle this week and was wondering what you all used to cool them i.e. what type of pump and radiators/fans and any links to where you go them would be great. thanks very much
17-07-2011 #2
Hi
I used a pump very similar to this one
http://cgi.ebay.co.uk/DC-12V-Electri...item3a681e17d2
and for the water tank I used one of the clip on sealing lid spaghetti storage boxes. I did have a small CPU rad and fan but this was way over kill. With the above my spindle barely gets warm.
Andy
17-07-2011 #3
I use a pump like this one ... much higher flow than the two already mentioned but I doubt it's required.
http://cgi.ebay.co.uk/WHALE-GP1002-1...item335da4ae7a
Just a covered bucket ... no heatsinks or radiators etc required as there's enough water for the heat to just radiate into the room via the bucket.
I've run it for several hours with this setup and the spindle was still cold.
17-07-2011 #4
thanks jonathan, just bought one of those
20-07-2011 #5
21-07-2011 #6
28-07-2011 #7
in China there is water chiller that could be controled the water tempreturer in certain degree. for example you can control the water tempreturer from 20 degree to 30 degree. And for the tempereturer scope there is many option for you. it's indeed like an air-conditioning.
cnc router,laser machine www.woodcncmachine.net msn/email: [email protected]
31-07-2011 #8
03-08-2011 #9
18-07-2011 #10
I will be using an old Lincoln Electric welding torch cooler. Its a bit on the industrial side but should work very well when I get the fittings and wiring sorted out. I will post some pics in my build log soon hopefully.
Ian
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
water cooling options for spindle
By routercnc in forum Tool & Tooling TechnologyReplies: 24Last Post: 12-02-2012, 11:22 PM -
(Video) Water spindle cooling system
By jafc76 in forum General DiscussionReplies: 0Last Post: 30-12-2011, 02:31 PM -
Spindle cooling pump
By p1lts in forum General DiscussionReplies: 3Last Post: 04-11-2011, 01:58 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
