Thread: chinese spindle cooling
28-07-2011 #2
in China there is water chiller that could be controled the water tempreturer in certain degree. for example you can control the water tempreturer from 20 degree to 30 degree. And for the tempereturer scope there is many option for you. it's indeed like an air-conditioning.
cnc router,laser machine www.woodcncmachine.net msn/email: [email protected]
31-07-2011 #3
31-07-2011 #4
02-08-2011 #5
VoltagesAC220~240VAC208~230VAC100~110VAC220~240VAC 208~230VAC100~110VFrequency50Hz60Hz50/60Hz50Hz60Hz50/60HzCurrent1.4~2.1A3.5~5.6A1.4~2.1A3.5~5.6ARefrige rating output2361Btu/h2999Btu/h2866Btu/h2361Btu/h2999Btu/h2866Btu/hRefrigerantR-134aRefrigerant weight300g320g280g300g320g280gCapacity6LInlet and outlet holdOutside dimensions 10mm brass connectorInside dimensions 8mm speedy connectorMax pumping lift10M100MN.W26Kg29KgG.W31Kg34KgDimensions (LXWXH)55 X 28 X 43 cmPackying dimensions (LXWXH)71 X 41 X 62 cm
03-08-2011 #6
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
water cooling options for spindle
By routercnc in forum Tool & Tooling TechnologyReplies: 24Last Post: 12-02-2012, 11:22 PM -
(Video) Water spindle cooling system
By jafc76 in forum General DiscussionReplies: 0Last Post: 30-12-2011, 02:31 PM -
Spindle cooling pump
By p1lts in forum General DiscussionReplies: 3Last Post: 04-11-2011, 01:58 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
