  1. #9
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Robin, the bends are 2m long...
    Just thinking, but is there any structural reason why the panels have to be done from 1mm thick sheet?
    Could you get away with thinner sheet?
    As for dies, given the number of parts you want to make, you could probably get away with dies made from untreated steel, and polished up. I've seen a good few homemade dies used, and they're good for short runs where the durability of commercial dies isn't needed. Still need to find somebody with a big enough press though!
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. RFQ: Gantry side panels
    By fvfdrums in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 03:50 PM
  2. RFQ: Panels cut from soft plywood
    By Rockeyes in forum Projects, Jobs & Requests
    Last Post: 12-04-2013, 04:38 AM
  3. RFQ: MDF Panels (+ More)
    By codytom in forum Projects, Jobs & Requests
    Last Post: 09-04-2013, 09:16 PM
  4. Where to get 1/8" sheet mild steel laser/water jet cut?
    By HankMcSpank in forum Marketplace Discussion
    Last Post: 10-02-2010, 01:28 AM
  5. Drill/Mill Spindle brake (RF30)
    By BillTodd in forum Machine Discussion
    Last Post: 04-11-2009, 12:09 AM
