for focus stacking i would just concentrait on camera stability and hand crank a gearbox attached to a 1mm pitch screw to drive it (backlash wont be an issue as you will only be driving in one direction at a time)
if your using CS5 i dont think you need overly consistant steps as long as your steps dont over reach your depth of field... if your taking a pictures of insects the slide only needs to be short
selecting the right ratio gearbox will take a little bit of maths (you dont want to be cranking it 30 times between each frame)
let say your typical DOF is 0.1 mm then your probably safe to crank 0.05mm at a time.
ergo, 1mm pitch screw 20/1 gearbox would give you 0.05mm per revolution
if you were going to play it safe a 40/1 gearbox would give you 0.025mm and a bumble bee would need aprox 680 frames.... OWCH!!!! i hpoe you can get a wider DOF than 0.1mm :)
a single linear bearing and short piece of rail would be ideal, pre-loaded if you can, they do come up cheap on ebay now and again as most people will only buy them in sets of fourLast edited by blackburn mark; 21-07-2011 at 11:58 PM.
The Following User Says Thank You to blackburn mark For This Useful Post:
22-07-2011 #2
i forgot to say that you need to remove the mechanical link to the feedback pot in the RC servo to get it to run endlessly in which ever direction (and speed) you dail into the servo tester
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
First couple of parts...
By Wal in forum Metalwork Project ShowcaseReplies: 10Last Post: 14-02-2014, 03:41 PM -
RFQ: Looking to get a couple gears modded
By m_c in forum Projects, Jobs & RequestsReplies: 3Last Post: 23-11-2013, 09:34 PM -
Materials used in CNC build projects
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 37Last Post: 25-09-2010, 08:54 PM -
NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
By m0nk3hjam in forum New Member IntroductionsReplies: 6Last Post: 17-08-2010, 02:32 AM
