    Quote Originally Posted by ECardenal View Post
    I see there are machined and not machined ballscrews, what's the difference ?
    'Machined' means the ends of the ballscrew have been turned on a lathe. This is to create a smooth and accurate cylindrical surface to attach the bearings and coupling. The ballscrew will not be accurate if the bearings are just placed on the threaded portion of the screw, if indeed they fit there at all. So in short, yes you do need end machining.
    If you get the ballscrew from linearmotionbearings2008 on eBay the end machining is extremely cheap - just a few £.
  2. The Following User Says Thank You to Jonathan For This Useful Post:
  1. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  2. First couple of parts...
    By Wal in forum Metalwork Project Showcase
    Last Post: 14-02-2014, 03:41 PM
  3. RFQ: Looking to get a couple gears modded
    By m_c in forum Projects, Jobs & Requests
    Last Post: 23-11-2013, 09:34 PM
  4. Materials used in CNC build projects
    By GeorgeD in forum Gantry/Router Machines & Building
    Last Post: 25-09-2010, 08:54 PM
  5. NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
    By m0nk3hjam in forum New Member Introductions
    Last Post: 17-08-2010, 02:32 AM
