    Jesus H Christ this is like pulling teeth, we have all the details including what you had for dinner but not what was asked.
    HOW MANY STEPS PER ARE YOU SET TO ?
    John S -
    Using EMC2, not mach3 so you don't set the steps per directly... you enter motor steps per rev (so 200 is correct), microsepping (so 16 in this case), pulley ratio (4.5 as discussed) and leadscrew pitch (120mm).
    It looks like at the moment you have the leadscrew pitch set to 100mm not 120mm .... so either change that or put the ratio to 5.4 and it'll be fine.
  1. 1:1 ratio - pulley sizes
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 12-04-2014, 01:30 PM
  2. Cutting HTD pulley(s)
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 11-12-2012, 07:19 PM
  3. pulley dims for boxford csb
    By onecut in forum Boxford Lathes
    Last Post: 23-09-2012, 04:58 PM
  4. 4th Axis timing pulley + Axminster bandsaw review
    Last Post: 09-04-2011, 07:31 PM
  5. WANTED: Timing Pulley Suppliers?
    By m_c in forum Items Wanted
    Last Post: 02-11-2008, 01:02 AM
