Thread: pulley ratios on 3 pulley axis
[QUOTE=2e0poz;22816]I played around with the ratio tonight and set it to 5.35 which brings it almost correct after some trial and error adjustment.
4.5*173.5/150=5.20 which is close to 5.35 ... doesn't make sense to me at this time of night though.
With 3200 steps per rev, and using 26.66mm per revolution as worked out in my last post that's 120 steps per mm.
Oh just notices, 5.35/4.5 is 1.188 ... i.e. very very close to 1.2, which is the factor the 24T pulley adds in. 1.2*4.5=5.4
So in conclusion try 5.4 and I bet it will be right...I'm not going to bet much though as it's getting late
20-07-2011 #2
Jonathan i tried 5.4 already and it was close but not quite. I will try again tomorrow with the DTI, i think sometimes we can only let the math get us most of the way there then rest is probably a bit of trial and error. i will set out a drawing to draw out markers, I have about 1300 cutting distance which is a large distance to loose on.
20-07-2011 #3
The difference between 5.35 and 5.4 is less than 1% ... I wouldn't be too surprised if there's that much error in the belt, particularly as it's quite long. I would definately try the DTI, or even attach digital calliper as that gets you 5 significant figures (unless your DTI is digital too). Digital calliper is not perfectly accurate, it will say the tolerances in the instructions. Either way it's better than a ruler which could account for the 1% error.
There was only one post to read when you replied :lol:
1:1 ratio - pulley sizes
By dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM -
Cutting HTD pulley(s)
By Jonathan in forum Metalwork Project ShowcaseReplies: 2Last Post: 11-12-2012, 07:19 PM -
pulley dims for boxford csb
By onecut in forum Boxford LathesReplies: 5Last Post: 23-09-2012, 04:58 PM -
4th Axis timing pulley + Axminster bandsaw review
By Jonathan in forum Metalwork Project ShowcaseReplies: 4Last Post: 09-04-2011, 07:31 PM -
WANTED: Timing Pulley Suppliers?
By m_c in forum Items WantedReplies: 4Last Post: 02-11-2008, 01:02 AM
