The difference in accuracy between C7 and C5 is not that much. Over an 800mm length you're surely going to have more inaccuracy caused by deflection of the frame/tool and the resolution / step accuracy of the stepper motors to an extent. The piece that the OP said is about 1m long will need to be strong and rigidly supported at the ends to not deflect by +-2thou.
http://www.mycncuk.com/forums/showth...curacy-V-Price
The C7 grade screws I have all seem fine, though clearly I have not got the kit to measure them that accurately. Either way leadscrews with the equivalent to C5 should be cheaper than ballscrews.
I would definitely use a screw on both sides linked by a timing belt. You could use two motors but then it's more difficult to keep it square. A small amount of skew will stop you getting 0.1mm tolerance. Why do you want that tolerance for kitchen worktop? How are you going to measure upto 800mm long to the nearest 0.1mm?
24-07-2011 #2
It's not for worktop, it's for cabinet components. As for the accuracy issue, let me explain it thus- if I make a cabinet with sides 720mm high by 565mm deep, and a base which is 564mm wide and 510mm deep (the difference in depth is for the back panel which is rebabated into the sides at 510mm from the front edge, but which is fixed to the back edge of the base panel) and the sides are actually 565.5mm deep and the base 509.5mm then there will be a 1mm discrepancy where the side meets the base at the front. That much discrepancy would be clearly visible, and even more obvious to the touch. Also the cabinet will be slightly out of square if the top of the side is 565mm and the bottom of the side is 565.5mm
At the moment when such discepancies occur I have to sand the proud part down until it is level with the other part (my cabinets are made from birch ply rather than laminate, so this is feasible) but I would much prefer not to have to do that and am prepared to go to some trouble and expense (I'm expecting this to cost me a good few hundred at least) to end up with an accurate machine.
24-07-2011 #3
It looks like repeatability is what you need, not accuracy which is good as even a poor quality screw will still be very repeatable.
Maybe make it so that you can easily put the base panel back on the machine to take a tiny bit off untill it fits?
Surely you would plane the proud part down, not sand it. Shouldn't take long to plane off a mm or so.
Have you considered making a complete CNC router ... then you can make it cut the holes rebates etc automatically.
24-07-2011 #4
It depends on whether it's still parallel- the accuracy is not just for ease of fitting the parts together, it's also needed to sure that the opposite edges are parallel, so that the compononent has all four corners at right angles.
A decent random orbit sander is faster, and the discs can be changed quickly when they wear out. Planer blades would ned to be TCT as the material can be quite abrasive
I have certainly thought about it, even been tempted once or twice. Holding the material down would be a problem, birch ply does not lie as flat as most kitchen cabinet materials, and a powerful vacuum pumo and system would be needed. There's also the issue of needed to learn quite a bit of software, whereas at the moment I can keep most of the numbers I need in my head, and the 8'x4' sheets to cut down in a quite logical sequence, and if one of the boards has a nasty knot in it I can easily cut around it to avoid it.
One fo the nice things about a machine such as I described in the original post is that I would be working with digits on a screen, rather than having to read a scale, something which I have a problem with, sometimes.
24-07-2011 #5
That shouldn't be a problem if you have an edge which is set precisely perpendicular to the saw to align the part against.
Fair enough ... I thought you meant sanding by hand which would be slow!
I currently either clamp sheet material at the edges, or screw it to the bed with normal wood screws. Both methods hold it adequately and are much cheaper than a vacuum bed. The only real disadvantage is you have to leave tabs (or position the screws carefully) to stop parts you are cutting out moving. Don't be put off by the software - CAMbam free edition would do what you need and is (in my opinion) very user friendly.
24-07-2011 #6
Well, the movable fence is the reference edge, so if it doesn't move accurately, if one end moves a little further than the other, then it won't be parallel to the cutting line. An edge that was at right angles wouldn't help if it was a narrow piece, for instance 565 x 80
Well, I am still considering it, so will bear that in mind, thanks.
24-07-2011 #7
RFQ: Anyone near Aylesbury or Oxford could lend a hand to a product designer?
By 8 ball audio in forum Projects, Jobs & RequestsReplies: 0Last Post: 01-11-2013, 01:10 PM
