13-09-2011 #91
Jonathan we have slotted holes on the gantry??
and as I said "I did the drawing dimensions off the ballnut support as it is fixed in place" but I suppose I lost a 1mm on the pencil line ??
James
13-09-2011 #92
I now know where I went wrong Jonathan my drawings where based on 20mm material and the material is actually 19.050075 however we do have slotted holes so that should be ok
James
13-09-2011 #93
13-09-2011 #94
Jonathan make it with the extra 1 mm as we can always mill it off if needed??
James
13-09-2011 #95
Just a small up date of parts I have
fitted or waiting to fit
as you can see the last photo is the extrusion waiting for Luke to fit
in photo 2 and 3 shows the transformer given by a really nice member of this forum
you know who you are, & a BIG BIG THANK YOU I will find a way of paying you. if not for the item then for the postage you have been warned
Items to get this month a forth stepper and a water pump for the spindle
Items to have machined this month Y , Z-axis supports Ie the 20mm material that connects y to z and z to spindle
belts for y and z plus pulleys and stepper mounts O'my god Jonathan has his work cut out for him
James
14-09-2011 #96
I think I may restart my build log?
what do you think ?
James
14-09-2011 #97
14-09-2011 #98
Hear hear.
14-09-2011 #99
OK Jazz it's just getting clogged up with silly comments by me and doesn't look very professorial at all
James
14-09-2011 #100
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
