22-09-2011 #121
Yes you are right
I may be able to make adapter plate when my cnc machine is running or at worst make new one's when it is finished so not all lost.
at least I have a shell to copy and the plugs are still usable
James
22-09-2011 #122
Yes they do look worth copying for £20 each...
More parts for you:
The bore of that last ballnut mount came out very shiny. I used a polished carbide tip in the boring bar from APT:
http://www.shop-apt.co.uk/carbide-in...m-uni-tip.html
I didn't do anything special - it was just cut dry with the auto-feed. Would definitely recommend them for getting a good finish on aluminium...
The Following User Says Thank You to Jonathan For This Useful Post:
23-09-2011 #123
Now that's looking good Jonathan
Just the gantry side's too do and I've got a long long weekend of work on my cnc
thank you they do look good
James
23-09-2011 #124
I have found the 6 pin connectors on ebay but would like advice on there load rating please before I buy as I seem to f-this up quite often
any way here is the link
http://www.ebay.co.uk/itm/10-6-PIN-M...ht_1240wt_1163
Thank you for looking in advance
James
23-09-2011 #125
James,
I think you said earlier that you were using Nema 23 motors(I think the Nema 23 peak at around 4.5 amps )so those plugs and sockets should be fine. You could always mount a little junction box next to the motors and connect them up that way like i did. Saves alot of hassle and time.
Ian
23-09-2011 #126
Ian
I thought they where nema 23 but they are SY60
James
23-09-2011 #127
I think that would be Nema 24 then. Still around 4amps max give or take a tad.
Ian
24-09-2011 #128
Yes they are 60mm, which seems to be referred to as Nema 24 though I doubt that's an 'official' size. They are rated for 4.2A per phase in parallel, so those connectors are fine...
I take it they're for the 'control box'?
By the way the CY cable arrived.... so we've got plenty now.
24-09-2011 #129
cool Jonathan I will see you Monday
I can't wait to see all the parts you've made for me and Luke
Luke has a short week this week he finishes school on Friday at 12.30 so we will be in the garage all weekend next week working on the CNC machine
Yes they are for the control box
James
25-09-2011 #130
There are currently 52 users browsing this thread. (0 members and 52 guests)
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
