06-10-2011 #141
Those pictures were probably taken before I de-burred them...either that or I forgot to do it! I've never got one of those tools as I didn't know if they were actually good, or just a gimmick, but since you've recommended that one I guess it's worth a try.
Generally to de-burr aluminium parts I use the edge of a steel ruler - probably not good practice but it's effective. Similarly if it's a hole de-burr by hand with a drill that's bigger than the hole.
06-10-2011 #142
I see.
Ok, that's true. I think I've got some spare M10 T-nuts as I made a load for my rotary table. Migh be M8, bit late now anyway.
Er... fine I suppose. Not so much to do now I'm back at University! I've just started continuing my (quite) high voltage stepper driver design/prototype as that's something I can do here.
That's suits me. By waiting do you mean have ordered or will order soon? If it's the latter then maybe don't bother as I will almost certainly have some.
09-10-2011 #143
Well after a long long week
LUKE has broken his foot now
So I have decided to crack on with the CNC machine
Now the frame is true and square (spent all day Friday doing this) fitted ONE side of the gantry side to my ballscrew but I have some binding on the other side (about 5mm out)
My rails are square and parallel but the gantry still refuse's to play. One side hits the end of the table and the other is around 5mm off (I can force the other side to meet the side at a right angel) but this is not right (every fibre of my body says "no, it’s not right") but I am all out of ideas
I am going to look at the bearing today to see if they are mounted correctly (all facing in the same direction) would this throw my gantry out of square??
I am at a loss to where things have gone wrong??
Does it matter if the bearing are pointing in the same way ??
The only two ways I can get the X-axis to run true is to force the right side over by about 5mm or have the table out of square
I’ve just taken some images of the machine and its now only out about 2mm
So I think I was over reacting and it was just crabbing
But I think I would still like a second opinion
any way here we have Luke striping out the old computer (sorry but Luke is in a bad mood :twisted::twisted:(tired me thinks)) not one smile and he told me not to take any more photo's of him
do you like my drives two Bosch drills :naughty::naughty:
today I'm going to tap my M10 T-nuts and start mounting the Y-axis
James:tup::tup:
09-10-2011 #144
James,
it shoudnt matter which way round you mount the bearings. Keep up the work, your doing well. Can you post a photo of where the parts dont meet so we can get a better idea of whats happening?
How do you manage to synchronize the bosch drills:heehee:
Ian
The Following User Says Thank You to Web Goblin For This Useful Post:
09-10-2011 #145
Thank you Ian I couldn't do it with out help from this web site and it's friendly members
Here is the two images of the x-axis bearings they should be in line but as you can see the right one is not tight to the MDF (about 1.5mm gap) But I can move it by hand.
this is the left side
this is the right side
Is this just crabbing or should it be in line as It's not under any load ??
James
09-10-2011 #146
The joint where the 6" wide plate bolts on to the back of the gantry would have to be perfectly square for the gantry to also be square. The distance is so great that the angle on those joints doesn't have to be out by much at all to get 1.5mm out. Also I'd be amazed if the frame is actually perfectly square, so using it as a reference could be misleading. The other thing is the position of the X bearing mount plates and hole positions - they could be slightly out too. All these tolerances stack up, so it's hardly surprising to me that there's a 1.5mm error ... don't worry about it.
If in the end the machine still wont cut square there's ways round it. If it's not much at all then you can position the X-home switches so that mach3 bends the gantry very slightly to square it when it homes. Clearly that's a bad plan if it's out by a lot as it would put a lot of strain on the structure and motors. You can also compensate in mach3 by using 'formulas' which enable you to make one axis a function of another axis. So you just put X=mY in the X formula box where m is the measured gradient / error. The difficult bit is measuring the error to start with as there's no straightforward reference.
Maybe he's using the steppers as encoders to provide feedback...
09-10-2011 #147
Thank you Jonathan
I feel a lot better now did you get my email?
I think the slight whip on the 12mm gantry support rail is not helping, I should be flat when both extrusions are bolted up to it. I was quite surprised when I offered the extrusion up to it and had to G clamp to get it flat.
all going well but I don't have a M10 starter tap, so I will have to get one in the week.
So a change of plan for today's work I'm going to mount the drivers in the old computer case
after I tidy my workshop/garage up (what a mess but not as bad as yours Jonathan:rofl::rofl:)
James
09-10-2011 #148
Luke,
did you measure the diagonals of your bed to make sure it was square? Its not out by alot.
If you are interested in taps I have some for sale at the moment. Pm me if you are interested.
Ian
09-10-2011 #149
You're welcome to borrow taps from me... but long term you might want your own anyway.
I got your email, thanks.
09-10-2011 #150
Thank you for the offer Ian and Jonathan But I have just bought some from ebay
I have a kit tap but it has no starter tap
yes the diagonals are spot on and all the material for the CNC machine has been digitally cut by the supplier
James
There are currently 28 users browsing this thread. (0 members and 28 guests)
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
