04-08-2011 #11
You're not using supported rails then
Will be ready by tomorrow...
12 bearing blocks!! That seems a bit extreme for two rails. I wonder how much difference it would make if you used more than two blocks per rail...
Anyway, centre height of the BK12 block is 25mm and total height of the SBR25 rail and block is 60mm. That means I need to make the centre height of the ballnut mount 60mm-25mm=35mm. Do you agree?
There are currently 44 users browsing this thread. (0 members and 44 guests)
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
