James,
I agree with i2i on this one. It might not be the side plates but the cross axis beam. It might not be perfectly square cut or it might be slightly short. If you have bolted up one side and its a bit short it would give this result when fitting up the other side.
Ian
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
