The reason I knurled it is because that's what John S does. Well, says he does at least. Could anneal the very end of the screw to stop the risk of cracking, but that's probably taking it too far.
Putting the extension on the 'floating' end sounds good to me as all it's doing is stopping the screw whipping, not transmitting torque. The other end is probably easier though as the tolerances to fit the pulley are not tight as for a bearing. It depends how much we need to add?
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
