    i2i's Avatar
    I take it you're going to replace the bearing clamp nut with a thread in the pulley. If so you'll need a more positive location for the pulley, one grub screw just won't be enough. Possibly a pin right through the pulley and shaft when it's clamped up tight.
  2. The Following User Says Thank You to i2i For This Useful Post:
