Well after a lot of soul searching I've decided to take it down to my local engineering shop and have it rematched if it doesn't work I will have to buy a new one but I'm not going to cut corners to make it work now
and if it works they can do the other one (z-axis) as that is the same
James
18-10-2011 #2
Rematched? Wont they charge a lot :(
I'll buy the old one if it is spare, then you don't loose out. Just need to get ball-nuts for it and that's my milling machine X and Y sorted. I need to do the end machining myself for that anyway.
What is the overall length of the Z-axis screw?
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
