    Useful ... yes MDF is not flat, but then again it depends what tolerances you're trying to work to. That resin impregnated sheet sounds worth looking in to.
    For me to cover my bed with 1.5x0.75" and 8mm slots would cost £475 even taking into account the 7.5% discount they give you for spending too much! Not really happening, though it would be a big advantage I can't really justify spending what my lathe cost on the router bed, could get a 60W laser and power supply for that :naughty:. I guess I could just do half the bed (1000*910mm, or 2000*455 but probably the former) and leave the other half MDF. As long as I skim them both equally that won't loose much, except it means I'll start using one end of the X-ballscrews much more than the other but that's not the end of the world. Would put a sheet of 3mm aluminium underneath half the bed to act as a coolant tray.... got a spare coolant pump.
    Anyway, I'm going a bit off topic there. I've put the slot in the mount as requested and the Z-axis is very close. Done a little wiring on the control box too.
    Yep thats why I said "Job dependent"
    Yes thats not a bad idea. . . I actually do put MDF full length down one side sometimes for jobs that are awkward to clamp or drilling and obviously don't need flatness.
    The good thing about MDF is that it's easy to screw into and for small parts that need profiling some times it's easier because the slots don't line up and make clamping hard if not impossible. Thats why the more and closer the slots are together the better really because it gives you more % chance of always dropping on a hole or something to latch onto with clamps or bolts.
    Has you probably Know full well Jonathan the bed and imparticular material clamping is an often un-thought about side of building a machine and can be a right pain in the arse. I can honestly say that yes while it was expensive other than the water cooled spindle it's the best upgrade I've made to my machine by far and wished I'd done it 2yrs sooner, makes work holding so much easier and far more accurate/repeatable.
    That's exactly why I'm hesitating. For almost all the parts I make I screw the aluminium down enough for the router to spot/drill the holes then use those holes for screws to clamp it properly and stop things flying when it is cut out. With the aluminium bed it's more difficult since I would clearly have to make the holes align with the slots which isn't always possible... never straightforward is it!
    Ye I used to think like that but belive me it is far better and you still can use MDF spoil boards for quick or awkward jobs. The only difference is I don't ever have to surface the bed when it's critical to flat and true. I find because of 45mm centres 90% of the time find a suitable hole or pocket. Drilling is the most trouble some for me but I often pocket holes anyway(If not loads holes) so it's not a big deal.
    One of the things I will often do when cutting several jobs that all have different needs is mix both MDF, HDPE and my card board spacer trick and use offsets G54, G55 etc.
    I have my bed divided up into area's and have spot drilled small registration dot's so I know the 0,0 of each offset. Then I just fasten each particular job down using which ever method best suits the job lining the board up with the ref marks, line the material up with the corner of the board then in CAM/code I always have the part just in from 0,0 stand back and let it rip.
    Depending on the jobs and time etc I don't always do it in one large piece of code, sometimes I'll have seperate code for each job just with the different offset coded in. This way I don't lose too much time unclamping re-clamping etc and can set the next job off straight away because I've set up the next offset while the previous job was cutting, just set the Z0 which is a 10 second affair with tool probe and away it goes again. . . It's quite efficeint.
    The other good thing about clamping MDF or HDPE boards is because of the accurate and parallel tracks and offsets I can easily remove and replace the board with work still attached. Sometimes I'll do really long jobs that can be 15-20+ hours long so some times don't want to leave the machine on unattended so pick a suitable point to stop the code but then some times find I need the machine for something else in the mean time.!. . . doing it this way I can clear the table for the new job but still be perfectly back in position and carry on at anytime.
    Like I say " FOR ME " it really has been a good improvement and worth the investment but everyone has different needs and ways of working.
    Yo oh oh James any news on progress.? . . .how close to making chips are we.?
    I'll let him answer this one
    They must be too busy making chips to answer! :):clap:
    edit...
    I know I will be! lol
There are currently 23 users browsing this thread. (0 members and 23 guests)
