Page 12 of 25 FirstFirst ... 2101112131422 ... LastLast
  1. #111
    I think I have cracked it what is your views on this drawing
    Extrusion 50x50 mm but the down side is they only do it in light
    James & Luke
  2. #112
    I think your latest design, but mirrored so that the Z-axis is mounted on to the same plate as the ballnut will be strongest:
    That way the spindle is closest to the Y-axis ballnut which should reduce flex parallel to the Y axis.
  3. #113
    It should be the other way around I don't how how that happened ???
    Thank you Jonathan
    Oops just realized you mirrored it all ready
    James
  4. James what thickness you using on the plates for Z?
    Michael
  5. #115
    Quote Originally Posted by m.marino View Post
    It's 3/4" - same as gantry sides.
  6. #116
    Ok my stepper motor covers have arrived but
    the stepper motor has 8 wires and the plug for the cover only has 6 pins
    are all the wires require ??
    do I need to buy new plugs for the stepper motors
    James
    I will add a photo later as I'm just having my eat
    James
  7. #117
    Quote Originally Posted by luke11cnc View Post
    James
    Nah you only need 4 pins wires are joined in pairs so only 4 needed.
  9. #118
    The reason they put 6 pins in probably in case you're using a unipolar stepper driver as that requires six wires.
    Which covers did you get out of interest?
  10. #119
    here is a link to the covers I bought
    http://www.ebay.co.uk/itm/2207881762...ht_1071wt_1163
    James
  11. #120
    It is as I feared, you bought the ones that 'will not fit the SY60 motor'. The motors you have are actually slightly bigger than Nema 23, so Nema24 ish...23 mean 2.3 inches, 34 means 3.4 inches etc...
    Maybe they can be modified. At least it looks like you only bought 2 not 4.
