	18-09-2011 #111
	18-09-2011 #112
	18-09-2011 #113
It should be the other way around I don't how how that happened ???
Thank you Jonathan
Oops just realized you mirrored it all ready
James
	18-09-2011 #114
James what thickness you using on the plates for Z?
Michael
	18-09-2011 #115
	21-09-2011 #116
Ok my stepper motor covers have arrived but
the stepper motor has 8 wires and the plug for the cover only has 6 pins
are all the wires require ??
do I need to buy new plugs for the stepper motors
James
I will add a photo later as I'm just having my eat
James
	21-09-2011 #117
	21-09-2011 #118
The reason they put 6 pins in probably in case you're using a unipolar stepper driver as that requires six wires.
Which covers did you get out of interest?
	22-09-2011 #119
here is a link to the covers I bought
http://www.ebay.co.uk/itm/2207881762...ht_1071wt_1163
James
	22-09-2011 #120
It is as I feared, you bought the ones that 'will not fit the SY60 motor'. The motors you have are actually slightly bigger than Nema 23, so Nema24 ish...23 mean 2.3 inches, 34 means 3.4 inches etc...
Maybe they can be modified. At least it looks like you only bought 2 not 4.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
