04-08-2011 #11
Just a little update on progress
I have received the following Items
8 SC20UU x 4 pcs Linear Ball Bearing these are for y,z axis
4 SK20 Shaft Support ID20mm Samic
3 X Stepper Motor - 3 Nm, CNC Mill/DIY
and I have ordered the following
three stepper mount for the above stepper motors from Jonathan Thank you Jonathan
Ball screw support ordered again from Jonathan
and -RM1605-1100mm with ballnut and end mached+ a set BK/BF12+1pc Coupler 8mm*10mm(8mm is for motor shaft) SBR25-1100mm(2supported rails and 12 bearing blocks)
Next on my list is the aluminium extrusion but not until I work out the size of my bed
I believe a thread lenght of 1063mm from a shaft length of 1100mm but I haven't decided the (y axis) length yet I think I may go with 700mm witch should give me a cutting footprint of 900x500?
the intended usage of this machine is oak,MDF,pine,acrylic and small amounts of aluminium (and even a plotter cutter for my wife crafting)
I have uploaded Draft sight and working on using it
James
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
