Thread: Single flute carbide cutters
14-08-2011 #21
21-08-2011 #22
as has been mentioned before, you will end up with a small dome in the center. These cutters plunge much easier than two flute cutters.
My 6mm single flute is actually 5.95mm. With the right data the cutting is very accurate.
I used 1mm two flute cutters in the past on aluminium and acrylic with very little success. But the single flute 1mm cutter did a fine job and is still in one piece after about 3 hours work in aluminium.
22-08-2011 #23
I accidently chipped one of the single flute cutters, but it turns out they are easy to regrind ... works just as well as new now. I was thinking I should buy some more in case these break... but it looks like they're immortal.
Just tried the same cutter on plywood, 14000rpm, 2800mm/min (so quite a high chipload) with 4mm depth of cut on spiral toolpaths. The cutter was quiet, left a good finish on the sides (but ripped the top not surprisingly) and did not heat up much so I'm sure it will go faster!
I did I video which I'll upload at some point.
Strictly speaking they leave a small right circular cone in the center.Last edited by Jonathan; 22-08-2011 at 04:59 PM.
22-08-2011 #24thats a dome to amyone with eyes over 30Strictly speaking they leave a small right circular cone in the center.
now then..... i hadnt thought about that :) i need to dig to the bottom of my tool tray and start doing some grindingI accidently chipped one of the single flute cutters, but it turns out they are easy to regrind
22-08-2011 #25
22-08-2011 #26
hahahaha!!!! you dirty rotter !!!
i have this habit of collecting shit with the feeling that one day it will all make sense, there should be a medical term for it
at my age now i have a magic box of shit and whenever i need a stange item or a thingymibob i have a root in my magic box and nine times out of ten i find just the thing :)
25-08-2011 #27
In the past I used two flute HSS and carbide cutters for my aluminium work. On my Syil X4 usually I did cut 2mm deep at between 5 to 8"/min (120 to 200mm/min).
With these single flute carbide cutters I can now cut 6mm (1/4") deep in one go. On my bigger X6 I can cut 1/2" in one go @ 100mm/min (4"/min). Plunging is a breeze.
Now, with these single flute carbide cutters I can cut much more efficient. And on my home made router I can now take 3mm (1/8") deep cuts in aluminium without problems. No more melting of acrylic either and 16mm cuts in MDF are a breeze... .
I uploaded two video's to YouTube
http://www.youtube.com/watch?v=re0IDJ8tzWw
http://www.youtube.com/watch?v=tC0rNbW9oV4
Compare these to a video I made some months ago and you will see why I am so happy. To add to the fun is the price of these single flute cutters. Cheap as chips.
http://www.youtube.com/watch?v=_2CHb...eature=related
Originally I made these video's for my machine supplier, personally I have no connection to Syil or to Titan. i also have a Sieg KX3 (excellent small mill) and a 3'x3 1/2' table router I made myself as well as a 5'x12' Forfun router from China. Yep, I am an addict...
25-08-2011 #28
i tried to watch the first two video's but they are private ??
so I can't view them
James
25-08-2011 #29
You set the video to private and can not view it.
25-08-2011 #30
sorry for that, have no idea really about this "modern stuff" but managed to change it. Hope you enjoy.
Carbide cutters
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 24-01-2014, 10:57 AM -
WANTED: 1/8" or 3mm Single flute carbide cutters
By craigrobbo in forum Items WantedReplies: 7Last Post: 09-04-2013, 06:49 PM -
4mm Carbide Cutters Single Flute?
By dazza in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 07:52 AM -
Single Flute vs. Ripper
By Tenson in forum Tool & Tooling TechnologyReplies: 11Last Post: 16-04-2012, 09:51 AM -
Cheap carbide cutters
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 6Last Post: 30-07-2009, 08:03 PM
