Thread: Single flute carbide cutters
14-08-2011 #10
Bigger diameter cutters are *much* more rigid, so you want to use the biggest you can for a particular part. Within reason though as clearly a bigger diameter cutter will remove a greater volume of material, so the cutting force is higher for a given depth of cut. It's a balance ... I thought 6mm was good in general, but if you're only cutting say 5mm sheet then 4mm would probably be fine. I wouldn't advise anything bigger than 6mm for a router.
I've got some 0.5mm, 3mm and 4mm on the way, though they are two flute (oops).
Carbide cutters
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 24-01-2014, 10:57 AM -
WANTED: 1/8" or 3mm Single flute carbide cutters
By craigrobbo in forum Items WantedReplies: 7Last Post: 09-04-2013, 06:49 PM -
4mm Carbide Cutters Single Flute?
By dazza in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 07:52 AM -
Single Flute vs. Ripper
By Tenson in forum Tool & Tooling TechnologyReplies: 11Last Post: 16-04-2012, 09:51 AM -
Cheap carbide cutters
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 6Last Post: 30-07-2009, 08:03 PM
