Page 3 of 6 FirstFirst 12345 ... LastLast
  1. #21
    Blimey, you're brave
    OTOH maybe you are cutting cheese or these are in stub length :naughty:
    PCBs ... so more like cheese on toast.
    I've used 0.8mm on the router with aluminium - it didn't break!
    Quote Originally Posted by luke11cnc View Post
    what about plunge cuts of flat bottom hole ??
    Using a spiral toolpath works well for that.
  2. #22
    James
    as has been mentioned before, you will end up with a small dome in the center. These cutters plunge much easier than two flute cutters.
    My 6mm single flute is actually 5.95mm. With the right data the cutting is very accurate.
    I used 1mm two flute cutters in the past on aluminium and acrylic with very little success. But the single flute 1mm cutter did a fine job and is still in one piece after about 3 hours work in aluminium.
  3. #23
    I accidently chipped one of the single flute cutters, but it turns out they are easy to regrind ... works just as well as new now. I was thinking I should buy some more in case these break... but it looks like they're immortal.
    Just tried the same cutter on plywood, 14000rpm, 2800mm/min (so quite a high chipload) with 4mm depth of cut on spiral toolpaths. The cutter was quiet, left a good finish on the sides (but ripped the top not surprisingly) and did not heat up much so I'm sure it will go faster!
    I did I video which I'll upload at some point.
    Quote Originally Posted by packmansdaddy View Post
    Strictly speaking they leave a small right circular cone in the center.
  4. #24
    thats a dome to amyone with eyes over 30
    now then..... i hadnt thought about that :) i need to dig to the bottom of my tool tray and start doing some grinding
  5. #25
    Hmm, if I hadn't said that I could have got myself a load of broken tools to regrind :lol:
  6. #26
    hahahaha!!!! you dirty rotter !!!
    i have this habit of collecting shit with the feeling that one day it will all make sense, there should be a medical term for it
    at my age now i have a magic box of shit and whenever i need a stange item or a thingymibob i have a root in my magic box and nine times out of ten i find just the thing :)
  7. #27
    In the past I used two flute HSS and carbide cutters for my aluminium work. On my Syil X4 usually I did cut 2mm deep at between 5 to 8"/min (120 to 200mm/min).
    With these single flute carbide cutters I can now cut 6mm (1/4") deep in one go. On my bigger X6 I can cut 1/2" in one go @ 100mm/min (4"/min). Plunging is a breeze.
    Now, with these single flute carbide cutters I can cut much more efficient. And on my home made router I can now take 3mm (1/8") deep cuts in aluminium without problems. No more melting of acrylic either and 16mm cuts in MDF are a breeze... .
    I uploaded two video's to YouTube
    http://www.youtube.com/watch?v=re0IDJ8tzWw
    http://www.youtube.com/watch?v=tC0rNbW9oV4
    Compare these to a video I made some months ago and you will see why I am so happy. To add to the fun is the price of these single flute cutters. Cheap as chips.
    http://www.youtube.com/watch?v=_2CHb...eature=related
    Originally I made these video's for my machine supplier, personally I have no connection to Syil or to Titan. i also have a Sieg KX3 (excellent small mill) and a 3'x3 1/2' table router I made myself as well as a 5'x12' Forfun router from China. Yep, I am an addict...
  8. #28
    i tried to watch the first two video's but they are private ??
    so I can't view them
    James
  9. You set the video to private and can not view it.
  10. #30
    sorry for that, have no idea really about this "modern stuff" but managed to change it. Hope you enjoy.
  1. Carbide cutters
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 24-01-2014, 10:57 AM
  2. WANTED: 1/8" or 3mm Single flute carbide cutters
    By craigrobbo in forum Items Wanted
    Last Post: 09-04-2013, 06:49 PM
  3. 4mm Carbide Cutters Single Flute?
    By dazza in forum Marketplace Discussion
    Last Post: 27-03-2013, 07:52 AM
  4. Single Flute vs. Ripper
    By Tenson in forum Tool & Tooling Technology
    Last Post: 16-04-2012, 09:51 AM
  5. Cheap carbide cutters
    By HiltonSteve in forum Tool & Tooling Technology
    Last Post: 30-07-2009, 08:03 PM
