Thread: Single flute carbide cutters
In the past I used two flute HSS and carbide cutters for my aluminium work. On my Syil X4 usually I did cut 2mm deep at between 5 to 8"/min (120 to 200mm/min).
With these single flute carbide cutters I can now cut 6mm (1/4") deep in one go. On my bigger X6 I can cut 1/2" in one go @ 100mm/min (4"/min). Plunging is a breeze.
Now, with these single flute carbide cutters I can cut much more efficient. And on my home made router I can now take 3mm (1/8") deep cuts in aluminium without problems. No more melting of acrylic either and 16mm cuts in MDF are a breeze... .
I uploaded two video's to YouTube
http://www.youtube.com/watch?v=re0IDJ8tzWw
http://www.youtube.com/watch?v=tC0rNbW9oV4
Compare these to a video I made some months ago and you will see why I am so happy. To add to the fun is the price of these single flute cutters. Cheap as chips.
http://www.youtube.com/watch?v=_2CHb...eature=related
Originally I made these video's for my machine supplier, personally I have no connection to Syil or to Titan. i also have a Sieg KX3 (excellent small mill) and a 3'x3 1/2' table router I made myself as well as a 5'x12' Forfun router from China. Yep, I am an addict...
25-08-2011 #2
You set the video to private and can not view it.
25-08-2011 #3
sorry for that, have no idea really about this "modern stuff" but managed to change it. Hope you enjoy.
18-10-2011 #4
Here's a video of the 6mm single flute on my router:
http://www.youtube.com/watch?v=bWmsu...=youtube_gdata
I think that was 1mm depth of cut... I now use a bit more at the same feedrate.
18-10-2011 #5
sweet
are you cutting dry ??
18-10-2011 #6
19-10-2011 #7
i find it a bit of a dilema when cutting small slots... adding coolant tend to make the chips stick in the slot so theres a lot of re-cutting of chips going on or cut dry and clear the chips with a bit of air
i cut acetal dry and use WD40 in alli like you say, a couple of dabs on each pass..... watching your vid has me thinking that it may be worth me trying to cut alli dry more aggressive than i do so the chips clear themselves and forgo the coolant, it might be interesting to see how long one of these cutters will last cutting alli dry
the voice in my head tells me it will all end in tears but without a bit of science i guess we would still be eating bananas
19-10-2011 #8
I use both methods when I care about the finish (either that or use a smaller cutter / cut wider slot). After the first few passes put coolant in the slot with pippete, wait for it to go round then blast the chips out of the slot with compressed air then put coolant back in slot and wait... repeat. Depends on the depth and size of the part you may not have to do this for every pass. If it's small part you do as otherwise the billet heats up a lot, then the chips start sticking.
Obviously the best way it to pump the coolant directly over the cutter, but that's not going to end well with an MDF bed!
I use the white soluble oil coolant from the lathe.
Carbide cutters
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 24-01-2014, 10:57 AM -
WANTED: 1/8" or 3mm Single flute carbide cutters
By craigrobbo in forum Items WantedReplies: 7Last Post: 09-04-2013, 06:49 PM -
4mm Carbide Cutters Single Flute?
By dazza in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 07:52 AM -
Single Flute vs. Ripper
By Tenson in forum Tool & Tooling TechnologyReplies: 11Last Post: 16-04-2012, 09:51 AM -
Cheap carbide cutters
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 6Last Post: 30-07-2009, 08:03 PM
