Thread: Aluminium CNC log.
01-08-2011 #21
01-08-2011 #22
I think you should go for the wider aluminium. It's annoying, but it won't hurt to have the Z axis a bit wider/stronger. It looks like you're using the same aluminium for Z... I'd make it stronger by putting the linear rails on the bit that moves up and down and the bearing blocks on the piece fixed to the gantry. That also saves a bit of aluminium/weight.
The stepper motor mounts have poor torsional stiffness...I'd either use bigger bar or plate or something.
Looks suspiciously like my spindle mount in the drawing :)
Wingardium leviosa.
01-08-2011 #23
it was your spinde mount, I tweaked it a bit.
The steppers will be mounted properly, that is just there for show as I cba drawing a Mount.
I'll give a go Jon, but I'm destroyed at the moment.
I got a new Motorbike today, I was so excited I couldn't sleep last night. so I didn't.
I'll to the metal shop tomorrow and see if they can do me a deal on some properly sized alu.
01-08-2011 #24
good luck JCB
on the deal that is :)
James
02-08-2011 #25
I've found some 180x12x80cm for £20.
not an excellent price compared to alu wharehouse but i'm not going to pay shipping so it's worth it.
04-08-2011 #26
Jcb
how is your build going have you made your bed yet (I sound like your mother LOL)
James
04-08-2011 #27
it's going ok, My mother bought me a new 125 on monday. It's an RG125 1994, by tuesday, it's broken.
so I have to split the engine, new gaskets and seals etc.
I'm going on holiday on the 13th and I'm waiting for my stuff from my man in japan (I wish japan!)
I'll probably start after my two week holdiday in newquay :)
04-08-2011 #28
04-08-2011 #29
04-08-2011 #30
[QUOTE=jcb121;23237]I had to but i didn't in first! there was no power in the bike at all! if anything they were riding it with popped seals.
QUOTE]
allways a risk when buying a second hand two stoke... especialy an RG:naughty:
£130!!! times have changed :confused: highly strung two strokes are murder for self distructing in first and second... i managed to melt an RD400 three times in the space of 500 miles(way back in the day when pistons and rings where cheap and power valves hadnt been invented)
if you let the motor reach its rev limit in first and second (ish) because of the low speed ergo low wind resistance and drag, the whole drive train goes slack and im pretty sure any lash in the motor causes enough vibration for the piston skirts start slapping against the liners, a bit chips off the skirt causing an imbalance causing more slapping and it quickly cascades into a disaster
over reving is much less important at 30mph (ish) and above as the wind resistance keeps the drive train nice and taught
Aluminium box section
By martin54 in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 28-10-2012, 01:13 AM -
First Aluminium cut
By luke11cnc in forum Computer SoftwareReplies: 15Last Post: 24-02-2012, 09:39 AM -
RFQ: Aluminium sculpture to be CNC'ed
By dav in forum Projects, Jobs & RequestsReplies: 6Last Post: 07-01-2012, 04:37 PM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
