Thread: Aluminium CNC log.
19-09-2011 #2
m_c ... looks like we're of the same mind - our last posts are virtually identical!
My mill has about 0.45mm backlash on X and 0.3mm on Y and it's no problem when using the machine manually. You just make sure to if it's a bigish cut lock the slide that your not moving, and when you move that slide to the required position compensate for the backlash by approaching the point in the same direction. You will also generally want to use conventional, not climb, milling.
Look for some thumbscrews that apply pressure to the gib strips to lock it. Don't move the other screws on the gib strips ...
Aluminium box section
By martin54 in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 28-10-2012, 01:13 AM -
First Aluminium cut
By luke11cnc in forum Computer SoftwareReplies: 15Last Post: 24-02-2012, 09:39 AM -
RFQ: Aluminium sculpture to be CNC'ed
By dav in forum Projects, Jobs & RequestsReplies: 6Last Post: 07-01-2012, 04:37 PM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
