Thread: Aluminium CNC log.
20-02-2012 #24
Even with those cheap drivers I would expect higher acceleration than you are currently using. Keep increasing the acceleration setting until either it stall or the machine shakes about too much, then back off a little to be safe. Aiming for something like 500-1000mm/s^2.
If you put a cable tie round each stepper motor that'll stop the plastic wire guard things snapping off.
Aluminium box section
By martin54 in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 28-10-2012, 01:13 AM -
First Aluminium cut
By luke11cnc in forum Computer SoftwareReplies: 15Last Post: 24-02-2012, 09:39 AM -
RFQ: Aluminium sculpture to be CNC'ed
By dav in forum Projects, Jobs & RequestsReplies: 6Last Post: 07-01-2012, 04:37 PM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
