    Quote Originally Posted by chip View Post
    i was wondering in order for them to be re-anodised would they need to be taken back to bare metal or can they just be steel wooled then re-anodised?.
    Anodising oxidises the outer surface of the part, then the dye bonds with that so to re-anodise and dye you need to remove the previous layer of aluminium oxide. If you submerge it in sodium hydroxide (NaOH / caustic soda) the aluminium oxide layer will be dissolved. However you have to be careful since that will reduce the size of the part, especially if you leave it in too long. If there's fine threads they could disappear...
  2. The Following User Says Thank You to Jonathan For This Useful Post:
  3. http://astro.neutral.org/anodise.shtml - pretty useful website about DIY anodising.
    Fabric dye not always work and fade with time. Commercial dye gives way better results
    I must try it some day
  1. Jcb water cooling adventure part two.
    By jcb121 in forum Metalwork Project Showcase
    Last Post: 04-07-2014, 07:46 PM
  2. Replies: 17
    Last Post: 18-09-2013, 06:32 AM
  3. water cooling options for spindle
    By routercnc in forum Tool & Tooling Technology
    Last Post: 12-02-2012, 11:22 PM
  4. (Video) Water spindle cooling system
    By jafc76 in forum General Discussion
    Last Post: 30-12-2011, 02:31 PM
