Thread: spindle bearings overheating
	03-05-2011 #1
I have been running my diy cnc mill spinde at full speed (3500 rpm ish) and it is getting excessively hot (ie too hot to touch for more than 5 seconds). The bearings are cheap taper rollers with a 1 " bore and I have tried oiling them with light oil and standard wheel bearing grease but are as hot in both cases. I did cheap out on the taper rollers as they are for trailer wheels and so I am not expecting super precision, however looking at similiar size cheepo TR bearings on the net the limit is 7800rpm with grease. They have a rubber seal on the outboard bearing and I have used this to seal the lower one. The top one is sealed using a close running 'labyrinth' but both are getting too hot. I have tried various preloads including as close to none as I could get but it does not seem to make any difference.
The bearings I have used are:
http://cgi.ebay.co.uk/2-X-L44643-446...item2eabddd0c5
Does this sound like a bearing problem, bearing misalignment problem or lubrication issue? I am not aiming for super precision but usable would be nice! The spindle in the workshop series of books 'Spinles' book uses similiar automotive bearings.
Thoughts appreciated.
Overheating stepper motors
By Skysurfer in forum Stepper & Servo MotorsReplies: 3Last Post: 01-08-2019, 11:43 AM -
By Skysurfer in forum Motor Drivers & ControllersReplies: 2Last Post: 06-05-2014, 12:40 PM -
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM -
FOR SALE: rails, screws, bearings and spindle
By wilfy in forum Items For SaleReplies: 16Last Post: 10-04-2013, 01:50 AM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
