Thread: VFD + motor
I think given what John has said ('Rotors on modern metric framed motors are OK'), and what I've read it would be safer to get a new motor.
If you're rewinding it to work for 200Hz then you'll have even less torque at 18Hz.
You've said the reason for wanting 1000rpm is for a fly cutter ...
For mild steel, 1000rpm is 32mm cutter diameter... 1mm depth of cut, 155mm/min, power is 63W (Wrong! See post #12)
For aluminium, 1000rpm is 140mm cutter diameter...1mm depth of cut, 310mm/min, power is 38W
If the VFD does manage to keep the torque constant at lower rpm (which it wont quite) then the power will be roughly, with 2.2kW motor, 1000/2800*2.2=0.79kW. ... so many times more than a fly cutter will use. A face mill will be the power above multiplied by the number of inserts - still probably ok (63*4<<0.79kW).
If you do the same power calculations for drilling (with above about 10mm drill) you'll find that it's more of a problem...however if there's a pilot hole that clearly reduces the required power.Last edited by Jonathan; 30-07-2011 at 05:28 PM.
30-07-2011 #2
30-07-2011 #3
It does... I made a mistake and forgot to change the width of the cut when I calculated those. If it is full width of the cutter, then for steel it is about 105W and aluminium 160W assuming cutting full width of cutter.
The conclusion for a fly cutter is still the same, however a face mill will require the power above multiplied by the number of inserts... so too much. The thing is does it really matter ... with the machine being CNC you can generally just increase the depth of cut untill you hit the power limit and leave it to take as many cuts as required.
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
