Thread: Breakout Board
30-07-2011 #2
17-08-2011 #3
My board will be ready in September, for those of you who are interested:
Features:
· Onboard high voltage regulator (70V Max)
· Dual power supplies;
o One 5V DC for the Parallel Port associated logiclevel circuitry.
o One isolated 12V DC to drive port-opto circuitry.
· Integrated Charge Pump for added protection, withoverride jumper for testing.
· Full optical isolation of all inputs.
· Buffered 2x relays, rated at 10 Amps 240V AC.
· The user will be able to select from a further combination of;
a) 2 out of 3 comprising 1x 10A relay, Charge pump and 0-10V for Spindlecontrol.
b) Channel Y Step and Dir or Y Step and Relay no4 (10A relay)
· Opto isolators can handle step signals up to 40 KHz
Regards,
Roy Stark
17-08-2011 #4
Good to see that you appear to be doing the isolation properly...more than can be said for some.
You could add an option for a different voltage range for spindle control.
40 kHz is a bit low. Most will only run at 25-35kHz with Mach3, but you can have more and a lot of drivers claim to do 200-300kHz.
17-08-2011 #5
actually the components i have used are rated at 80kHz, i am just being cutious.
Regards,
Roy Stark
17-08-2011 #6
17-08-2011 #7
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
breakout board usb or parallel
By crossleymarko in forum Motor Drivers & ControllersReplies: 13Last Post: 30-07-2013, 12:44 PM -
Breakout Board Comparison
By 200thhorseman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 27-03-2012, 12:28 AM -
FOR SALE: PMDX-122 Breakout board
By IN-WondeR in forum Items For SaleReplies: 0Last Post: 14-12-2011, 04:05 PM -
eBay: CNC Breakout board cheap - that will do me !
By Lee Roberts in forum Items On eBay UKReplies: 9Last Post: 14-08-2009, 05:52 PM
