OK, I just mentioned to spindle in passing as it is pulse width sensitive.
Just download the latest version to check and it's impossible to have different pulse widths setup for different axis.
It doesn't matter if you have 15 power supply's or driver, you only have one copy of Mach.
The pulse width setting I'm talking about is in Config > Motor tuning. Step pulse which is slightly to the right at the bottom of the screen. Any alterations HAS to have the save setting button pressed then OKJohn S -
Machine Slow on Curves
By swisscheese in forum Computer SoftwareReplies: 31Last Post: 12-04-2014, 12:49 AM -
x-axis on Orac losing direction
By asto in forum Motor Drivers & ControllersReplies: 3Last Post: 29-03-2013, 01:22 AM -
Forum Slow
By pcstru in forum General DiscussionReplies: 3Last Post: 27-01-2011, 03:54 PM -
Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
By fasteddy in forum Motor Drivers & ControllersReplies: 9Last Post: 14-05-2010, 02:32 PM -
stepper speed very slow
By jonm in forum Stepper & Servo MotorsReplies: 17Last Post: 02-11-2009, 12:39 AM
