31-07-2011 #7
Are you using the lowest Kernel frecquency, 25kHz? If that isn't sufficient you may need to use 400 step/rev.
I would check the bios ... disable everything you can that's not useful.
Changing the pulse with from 0 to 5us wont make a difference as it defaults to 5us if you put 0 (I think, might be wrong).
Have you ran the driver test program to check the parallel port? If not I'd start with that...Last edited by Jonathan; 31-07-2011 at 09:54 AM.
Machine Slow on Curves
By swisscheese in forum Computer SoftwareReplies: 31Last Post: 12-04-2014, 12:49 AM -
x-axis on Orac losing direction
By asto in forum Motor Drivers & ControllersReplies: 3Last Post: 29-03-2013, 01:22 AM -
Forum Slow
By pcstru in forum General DiscussionReplies: 3Last Post: 27-01-2011, 03:54 PM -
Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
By fasteddy in forum Motor Drivers & ControllersReplies: 9Last Post: 14-05-2010, 02:32 PM -
stepper speed very slow
By jonm in forum Stepper & Servo MotorsReplies: 17Last Post: 02-11-2009, 12:39 AM
