    Changing the pulse with from 0 to 5us wont make a difference as it defaults to 5us if you put 0 (I think, might be wrong).
    No it should sat at what ever you put in. A low setting can cause problems for some drivers as they don't have time to read the pulse.
    Where it affects machines the most is on spindle speed.
    What concerns me is the statement "Just checked and only the X axis had the pulse width set to 0, and it was running fine, have set it to 5 now.. z and y were already set at 5"
    You cannot have different values for different axis, what is set for one is set across the board - unless the latest version - which we don't use is different, perhaps I need to check.
    John S -
    Short video of z axis motor stuttering.. Turn the sound up and you will hear it 'jumping'...
    You can only see the video if you are logged in to fazebook.
    John S -
  1. Machine Slow on Curves
    By swisscheese in forum Computer Software
    Last Post: 12-04-2014, 12:49 AM
  2. x-axis on Orac losing direction
    By asto in forum Motor Drivers & Controllers
    Last Post: 29-03-2013, 01:22 AM
  3. Forum Slow
    By pcstru in forum General Discussion
    Last Post: 27-01-2011, 03:54 PM
  4. Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
    By fasteddy in forum Motor Drivers & Controllers
    Last Post: 14-05-2010, 02:32 PM
  5. stepper speed very slow
    By jonm in forum Stepper & Servo Motors
    Last Post: 02-11-2009, 12:39 AM
