Thread: Stepper motor as a generator??
Jonathan, that's one of or more likely the best DIY turbine generator I've ever seen but I'm afraid my budget couldn't handle this project and put my skills to the test :).
I honestly thought about VAWT- there are some advantages of this kind of turbine- especially in urban turbulent winds. They are slower than HAVT so they require generator to kick at lower rpm, but without messing with some kind of reduction bigger dia generator (more magnets and coils thou) of your kind from previous post would perfectly do.
What do you think about VAWT Jonathan?
03-08-2011 #2
Thanks.. it was my A-level project. I've not found another DIY turbine with active pitch control. I went much further than required for the A-level though. I've not done anything with it for over a year now :( ... I'm intending to test the generator with lathe on VFD as that'll be a more accurate setup than using the school Bridgeport to get readings. I machined all the parts manually... no CNC.
That's what I heard, but there's so many more sources that say they are not as good generally. How many commercial VAWT's have you seen?
For mine to 'kick' at lower RPM you just need to increase the number of turns on the coils since the voltage is proportional to the number of turns. Just make a test coil out of anything, spin the generator at known RPM. Then you get volts per turn per rpm ... decide what cut-in speed you want and just scale it to get the required number of turns. Then work out the biggest wire you can fit in the available space ... use multiple strands if it's too big to wind easily.
Forget it... there's just more to go wrong.
08-08-2011 #3
Jonathan have a loot at this video, It nicely shows how turbulent wind is in urban area.
http://youtu.be/rLa_NY5U1nk
Do you think HAWT is able to follow so changing wind direction ?? I doubt it.
08-08-2011 #4
[QUOTE=wiatroda;23291]Jonathan have a loot at this video, It nicely shows how turbulent wind is in urban area.[/URL]
The thing is it will vary for each site, which in my opinion makes discussing in general terms not very productive.
The VAWT in that video is a drag based machine (so TSR<1), so is inherently inefficient compared to any HAWT, and better VAWTs. At a higher windspeed (which after all is what we're interested in since power is proportional to wind speed [b]cubed[b/]) the turbine with TSR>1 (i.e. VAWT or HAWT with airfoil profile blades) will generate much more power. If the wind is turbulent then I think neither of this type will be that effective since when the wind is coming from many different directions the resultant force on each 'section' of the blade will be different - so the overall torque may not be that much. So that implies that yes a drag based VAWT would work better than HAWT in turbulent wind, but still not generate much power as it wont benefit from higher windspeeds. Also in tubulant winds fatigue on the VAWT blades, which are already highly stressed compared to a HAWT, will be greater possibly leading to faliure.
I tend to agree that VAWT should be better in turbulent wind, just from common sense. I think that it's not worth considering having a wind turbine if your site is very turbulent (unless you don't need much power, say off grid). However if you've made it yourself, and therefore very cheaply then why not experiment... design the generator so you can try VA and HA with the same swept area and compare.
If the wind is that turbulent then you should just put the turbine higher, and use a HAWT. Granted planning permission is an issue, but it's clearly the best way.
Not one of a useful size, the moment of inertia is high and therefore cannot accelerate into the wind without a larger force from a big tail, and the gyroscopic forces would be large, so it is going to need a very strong tower to do that ... etc it's just not worth it.
Also in the video it says 'The HAWT will turn in lighter winds so it it more efficient' ... which is a bit of a dodgy statement.Last edited by Jonathan; 08-08-2011 at 09:59 PM.
08-08-2011 #5
That's what I thought to build, both HA and VA and compare performance ( generator can be the the same to cut costs and make whole experiment more data accurate) .
Permission makes me hesitate to build either one of them but the idea is still in back of my head. My garden location is very turbulent place and that's why I consider VAWT more appropriate for this location. Lots of reports say vawt doesn't need tower to be so high as havt so there is less risk it will fall to neighbours' gardens :). When I have some spare time (or money) I think I'll play a bit with stepper as generator and to control load by PWM proportionally to rotor RPM. Just an another idea.
Anyway, your generator looks superb. When are you going to put it up?
08-08-2011 #6
Lots of reports say that wind speed increases with altitude, from which you can conclude that having the turbine near the ground is less effective.
Thanks, but there's still things I would improve if I made another one. No idea when as we don't have space for it (according to my Mum and Dad). I'm waiting for an opportunity to appear to mount it...
What size stepper motor do I-need.
By irving2008 in forum Stepper & Servo MotorsReplies: 46Last Post: 15-06-2017, 09:18 AM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Running a three phase router/mill on a generator?
By gavztheouch in forum General ElectronicsReplies: 3Last Post: 19-02-2013, 12:39 PM -
Stepper motor help.
By Kammo1 in forum Stepper & Servo MotorsReplies: 4Last Post: 12-02-2010, 11:11 AM -
Stepper motor help
By Mucky Mike in forum Stepper & Servo MotorsReplies: 2Last Post: 04-04-2009, 04:25 AM
