Page 11 of 16 FirstFirst ... 910111213 ... LastLast
  1. Bruce,
    Yes if you would please. Though I will be honest I will still go with a local VFD which for me saves the cost of keeping the back up in house currently.
    Saving up for that is okay. Thanks for mentioning Collet size Jonathan as that is probably the best reason to move up from the 1.5Kw unit even though I really don't need that much more power. Seven millimeters is just not big enough by one millimeter to do the range of tools that I have reason to use.
    Today more set up an prep work in shop and business work. Long day today.
    Michael
  2. #102
    Quote Originally Posted by m.marino View Post
    Not that I want to change your decision, but the collets on the 1.5kW are ER16 which goes up to 10mm:
    http://www.rego-fix.ch/eng/katalog/ti/ti_fs.htm
    (I think you were looking at ER11 which is up to 7mm)
    For most people over 10mm is critical as it means you can use 1/2" router cutters.
    Remember that the available power output from the spindle is roughly proportional to the spindle speed, so if you're starting with 2.2kW instead of 1.5kW you have more power at lower speeds. So saying 1.5kW is more than you'll ever need I think is not quite true as it doesn't take into account this power reduction.
  3. Jonathan,
    ALL the 1.5kW water cooled spindles I have looked at are ER11, now if you know of one that is ER16 great please post the link for it.
  4. #104
    Jonathan,
    Fair enough the only ER16 1.5kW are air cooled and you don't want that. To be honest I'd never bothered looking before as I didn't consider it.
  5. Well the wiring that I ordered is here (limit switches and lighter then what you have Jonathan as don't need that heavy for the limit/Home switches). Jazz showed me a few web sites that have some really nice stuff that will really help with product once I can afford them. Most likely going to put a smoothstepper in front of getting the water cooled spindle as that just means keeping an eye on the brushes of the Kress and using the Ear plugs I use already for a bit longer.
    Right now it is getting down to the end bits and bobs that are needed to get things finished. Hope everyone is doing well.
    Michael
    edited to correct spelling
  6. #106
    I think you should definitely prioritise the spindle over the smooth-stepper. Since it's only quite a small machine you'll be able to run it perfectly well from the parallel port, so I doubt the smooth stepper will make much difference. Compare that to the spindle which directly affects the machine's ability to cut accurately and efficiently.
    I'd like a smooth stepper too (as mine is bigger), but I'm not bothered when really as the machine runs perfectly well. It should just be a little more stable with one. Just going to wait for one to come up cheap...or make my own version. Whichever comes first.
  7. #107
    Lives in East Lothian, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    Jonathan, do you even know what Michael makes with his machine?
    I'm pretty sure he doesn't need 2.2kw to machine what he does, and I'd even say the kress has far more power than what's needed. I'll agree a water cooled spindle will be better for noise reduction, but I wouldn't say it's a priority.
    As for the smoothstepper, if you do get one, the ethernet SS is very near production, and is reported to be far more stable than the USB version.
  8. #108
    Yes I do know - spent some time discussing quite a lot about this and the machine over Skype, but not going to say here as that's up to Michael. I gather what he is making requires high accuracy. It's also generally small tools, so I guess the cutting noise wont be much which makes getting a quieter spindle sensible.
    Yes if you actually got 2.2kW from the spindle - see what I put in post #102. Similarly if the Kress had far more power than needed Michael wouldn't have considered getting a Super-PID.
    More importantly he needs the bigger collets that the 2.2kW spindle offers, so the only spindle to get is the 2.2kW water cooled (as air is too noisy and bad at low speed).
  9. Jonathan,
    I would prefer to have the 8 mm that a ER16 allows an ER20 is overkill for me. While I will be working with some metals in the future that is a bit down the road and I primarily work with plastics that need a high finish. With the machine as it is I will easily be able to do that with out a big problem with the Kress as the position I was in with the old machine was the machines in ability to be any where as near as accurate as I needed.
    m_c,
    thanks for the heads up on the smoothstepper and I will be waiting whether I wanted to or not as have too much to get done that requires funds going other places. The good news is that will be generating income and with the new machine should have a very nice return. Which will go part in the bills to live, part into paying more materials to meet orders and parts to be saved up for upgrades as possible.
    Hope every one is doing well and m_c; once I have it up here from Jazz, drop me a message and we can see about that project you need cut.
    Michael
  10. #110
    Thou M/C don't hold your breath because the B'#*?ard is fighting back and has started taking root . . :rofl:
  1. CNC Build - TEP milling machine conversion
    By craynerd in forum Gantry/Router Machines & Building
    Last Post: 06-07-2015, 02:09 AM
  2. Someone to help me build a machine
    By mandev in forum Gantry/Router Machines & Building
    Last Post: 29-01-2014, 02:07 PM
  3. DIY Machine to Build?
    By paulkane1 in forum Gantry/Router Machines & Building
    Last Post: 03-12-2012, 02:24 PM
  4. NEW MEMBER: Second machine build
    By tmsboss in forum New Member Introductions
    Last Post: 04-09-2010, 01:11 PM
  5. Best Type of Machine to Build?
    By Kevin in forum Gantry/Router Machines & Building
    Last Post: 05-08-2009, 02:50 PM
